Rebuilding
Rebuilding Empty Rebuilding
Post by deputydogg659 Wed Jun 22, 2016 7:37 pm
So I have taken the motor apart but iam not able to separate the heads or the jugs from the block or case any ideas on how to make this happen. Iam looking for someone interested in helping me rebuild the engine or at least to tell me what I need to get this project back on the road this summer. I don't know anything about these engines and there are soooooo many different versions.
deputydogg659
Number of posts : 8
Registration date : 2016-05-20
Rebuilding Empty Re: Rebuilding
Post by Attorney Isaiah Loophole Wed Jun 22, 2016 10:14 pm
If you have all 16 nuts (8 per side) that hold the heads on then you can use a rubber mallet hitting straight down on the fins to try and get things apart. If the engine is locked up and there is a lot of corrosion it may not be possible without cutting things.....and if it comes to that then the engine is probably junk.....
Post by deputydogg659 Wed Jun 22, 2016 10:18 pm
Pretty much what I was afraid of because I've already tried that that's why I was trying to find a Volkswagen guy I'm new to these engines and all the little things you gotta do I wish my budget was large enough I just swing away at it but I'm trying to save as much as I can so I have to buy as little as possible within reason our place what needs to be replaced but I just want to play this summer and maybe rebuild this winter but with that being said I don't like buying things twice so it's something for a few dollars more to get the better quality go ahead and do that
deputydogg659
Number of posts : 8
Post by deputydogg659 Sun Aug 07, 2016 7:30 pm
So the motor was no good case was very eaten up and a long story short I found a better deal sooooo sorry to my vw guys but it got a new heart a 12A mazda rotary with plate for 300. Rebuilding 20160810
Rebuilding 20160811
deputydogg659
Number of posts : 8
Post by Attorney Isaiah Loophole Sun Aug 07, 2016 8:23 pm
That was a deal on the rotary with an adapter! It should be fun!
